Results 1 to 9 of 9
Thread: DIY Milling Machine
    Supporting Member MaximumDIY's Avatar
    Aug 2019
    MaximumDIY's Tools
    DIY Milling Machine
    Home made milling machine - Maximum DIY style.
    For years I've always wanted a milling machine but they are too expensive and I just couldn't bring myself to pony up to dosh. So I decided to make one myself out of spare parts I had laying around, the results are pretty amazing.
    It's not an industrial machine and it seems to work fine making small cuts - perfect for my needs.
    Parts used:
    The power spindle motor is a 2400 watt electric motor salvaged from a paint sprayer pump.
    The power feed for the Z axis (up and down) is the climb motor from a treadmill - this is a strong geared motor which is used to raise and lower the spindle head.
    The X axis (left and right) power feed motor is a 12v window wiper motor from an old car - the speed control is a 12v 20amp PWM circuit. The power feed is manually engaged by using a 19mm 12point socket that can slide back and forth connecting the powerfeed drive to the table using a hex head on once side and square on the other, once engaged the table will move back and forth at the desired speed. Please see photos attached
    The pulleys were all hand using the lathe made as they are quite expensive, the switches, plastic boxes, bearings and machinist vice were all purchased from eBay in an attempt to keep the cost down.
    Parts made:
    The main support column was made from an old bench grinder stand - I placed it on the lathe to square it up and it worked perfectly. There are various other parts that were made on the lathe such as the main shaft, this is a 35mm steel shaft that uses an internal M3 taper to house the cutting tool which is held in place by a head bolt connected at the top of the spindle shaft.
    This is tried and tested method on professional machines to prevent the cutting tool from leaving the machine due to vibration.
    Spindle: The spindle was hand made on my lathe out of Bright Steel from memory it was 40/40 cold rolled steel.
    Taper: The taper is an Morse3 taper, I decided to use this shape as tooling is quite cheap and will also fit my lathe tail-stock.
    Bearings: The bearings were I used were pillow block cast bearings UCF207 35mm ID, they were the only bearing in my price range and they seem to do the job well.
    The compound table was purchased form a machining store as it's quite strong and sturdy and far too difficult to build without access to a professional milling machine. The 4" vise was another eBay purchase - links below
    Accuracy:
    The home made spindle has a run-out of 0.004mm which isn't too bad for a DIY job.
    If you like this video please leave me a comment - Like / Share / Subscribe
    Thanks for watching
Name:	M3Taper Setup.jpg
    Powerfeed images
ID:	30862 Click image for larger version.
ID:	30863 Click image for larger version.
ID:	30864 Click image for larger version.
ID:	30865 Click image for larger version.
ID:	30866Click image for larger version.
ID:	30887Click image for larger version.
Name:	3 step Pully.jpg
    Ebay Parts listing
    ER32 Collet Set
    https://rover.ebay.com/rover/1/711-5...72.m2749.l2649
    4" Milling Machinist Vise
    https://rover.ebay.com/rover/1/711-5...72.m2749.l2658
    M3 Face Milling Cutter
    https://rover.ebay.com/rover/1/711-5...refresh%3Dtrue
    Pillow Block Bearing UCF207 35mm
    https://rover.ebay.com/rover/1/711-5...item521a81bdc0
    Last edited by MaximumDIY; Aug 27, 2019 at 05:14 AM. Reason: Viewers requested additional information about home made machine and parts used.
  2. The Following 16 Users Say Thank You to MaximumDIY For This Useful Post:
    Altair (Aug 26, 2019), Andyt (Aug 27, 2019), baja (Aug 27, 2019), bruce.desertrat (Aug 26, 2019), Christofix (Aug 28, 2019), DIYSwede (Aug 24, 2019), Drew1966 (Aug 26, 2019), EnginePaul (Aug 26, 2019), Gromet (Aug 27, 2019), high-side (Aug 26, 2019), jjr2001 (Sep 2, 2019), Jon (Aug 23, 2019), jonnydot (Sep 2, 2019), JTC (Aug 26, 2019), Midwestern640 (Aug 30, 2019), olderdan (Aug 25, 2019)
