Results 1 to 5 of 5
Thread: Double nut trick for tight spaces - GIF
    bob_3000 (Aug 4, 2025), emu roo (Aug 3, 2025), nova_robotics (Aug 3, 2025)
    Supporting Member odd one's Avatar
    Apr 2020
    WNC
    odd one's Tools
    Works, but if you can reach in there with a piece of all thread, you can probably reach in there with a pair of long needle nose pliers holding the nut as well. If it is too deep, then you would not have enough swing on the wrench to tighten it.
  4. The Following 2 Users Say Thank You to odd one For This Useful Post:
    I have a couple pair of these they work really well for work like this
    Dec 2018
    Or a latex glove, and a drop of super glue on the finger tip to hold the nut on, or the same on a tongue depressor, popsicle stick, screwdriver blade, or the sides of the open end wrench. Lots of ways to get this done.
  8. The Following User Says Thank You to RetiredFAE For This Useful Post:
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    Or - my solution that I have used many times is to put a piece of tape on the wrench down side, put the nut in the wrench and then screw the allthread into the nut and wrench away. I have used this on horizontal threads that were recessed pretty far as well, even crimped a thin wall tube to extend the wrench so I could reach further back...
    A Handy Tool To Get A Nut In A Small Space
  10. The Following User Says Thank You to BuffaloJohn For This Useful Post:
