Quote Originally Posted by ncollar View Post
Marius
The idea of using a drill press as a mill has been around since the beginning of time. The spindle and the bearings are set up to cut in one direction that is down. Any side ways movement will do nothing but wear a bearing that is not designed for that. Not just that but the chuck will more than likely shack itself off. If you go forward with the idea make sure you have a good supply of cutters because the sizes you will be able to use are rather fragile.
Thank you for advice!
