Results 1 to 10 of 19
Thread: Drill Press Table Modification-------E Z Clampable drill press table
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Drill Press Table Modification. Made from 3/4 inch Doug fur and 5200 calking.
    How many times have we wanted to use clamp on a vise or work piece on the drill press table, only to find those support ribs right in the way.
    So my answer to this is to fill up the space with wood and now I can clamp any where I like as well as use the bolt holes. you can to now.
    enjoy.
    note 5200 marine calking is so strong I have used it to seal thru hull fittings.I had to double shim it on either side of the slot under the wood to get it level,so when I put the clamp on it would not brake the wood. Be sure to fasten all work properly.
    Drill Press Table Modification-------E Z Clampable drill press table-001.jpg
    Drill Press Table Modification-------E Z Clampable drill press table-003.jpgDrill Press Table Modification-------E Z Clampable drill press table-002.jpgDrill Press Table Modification-------E Z Clampable drill press table-004.jpgDrill Press Table Modification-------E Z Clampable drill press table-005.jpg
  2. The Following 32 Users Say Thank You to Captainleeward For This Useful Post:
    AmateurMachinist (Apr 5, 2019), benkeller3 (May 7, 2018), billd (Sep 6, 2018), bruce.desertrat (Dec 23, 2017), Caliper Ken (Dec 21, 2017), clydeman (May 6, 2025), emu roo (May 20, 2026), greyhoundollie (Sep 6, 2018), high-side (Jul 4, 2020), jackhoying (Jul 2, 2020), jackman (Dec 22, 2017), jjr2001 (Dec 22, 2017), JoeVanGeaux (Jun 15, 2018), Jon (Dec 18, 2017), mudnducs (Dec 20, 2017), NortonDommi (Dec 20, 2017), olderdan (Dec 18, 2017), Paul Jones (Dec 18, 2017), Peter Sanders (Dec 22, 2017), Priemsy (Jul 2, 2020), rlm98253 (Dec 18, 2017), rossbotics (Dec 18, 2017), Seedtick (Dec 18, 2017), tonyfoale (Dec 23, 2017), Tooler2 (Jul 9, 2020), Toolmaker51 (Dec 19, 2017), Tuomas (Dec 20, 2017), volodar (Sep 7, 2018), will52100 (Sep 6, 2018), WinDancerKnives (May 7, 2018), Wmrra13 (Dec 21, 2017), Wobblybootie (Dec 19, 2017)
    Dec 2013
    Florida
    rossbotics's Tools
    Good idea Capt.
    Comments are always welcome
    Doug
  4. The Following 3 Users Say Thank You to rossbotics For This Useful Post:
    emu roo (May 20, 2026), Paul Jones (Dec 18, 2017), Peter Sanders (Dec 22, 2017)
    Jul 2014
    Thanks Doug. Merry Christmas to you.... :O)
  6. The Following User Says Thank You to Captainleeward For This Useful Post:
    olderdan's Tools
    Brilliant, I love these simple idea's that are sooo useful, I will be copying this one.
  8. The Following 3 Users Say Thank You to olderdan For This Useful Post:
    Captainleeward (Dec 18, 2017), emu roo (May 20, 2026), Paul Jones (Dec 18, 2017)
    Jul 2014
    Hello Olderdanman, Thanks enjoy and Merry Christmas to you. :O)
  10. The Following User Says Thank You to Captainleeward For This Useful Post:
  11. #6
    May 2017
    Hey, well done. Better than good..............excellent.
    Merry Chrismas & thank you.
    Dave from "Downunder"
  12. The Following 2 Users Say Thank You to davidhoneybadger For This Useful Post:
  13. #7
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    They are called Tee Nuts or, more properly, Tee Slot Nuts:
    https://www.bing.com/search?q=Tee+Nu...ZI&form=MOZLBR
    https://www.mcmaster.com/#tee-nuts/=1aqu7s5
    Not the sheet metal ones that are made for wood. But the ones that are machined from solid steel. They come in many sizes and you need to buy some that fit your table's slots. Then you can locate a stud at any place along the slot. They work with Tee slots that are found on the better tables and also with just plain through slots as found on the less expensive DP tables.
    You can buy complete clamping sets, also in different sizes:
    https://www.mcmaster.com/#t-bolt-clamps/=1aqu8z6
    Or just buy the nuts and studs and use your own clamps.
    Paul A.
  14. The Following User Says Thank You to Paul Alciatore For This Useful Post:
  15. #8
    Jul 2014
    Hello Paul A. Your suggestion to use TeeNuts is a good one. I personally like to use clamps for the set up, much quicker and no oil and swarf on my hands...
    plus the swarf gets in the threads and nuts making them hard to turn, yes, clamps work best for me gosh what a time saver..Merry Christmas to you aswell. an ...Thank you for your suggestions,
    To Dave from Downunder.....I have been to Australia beautiful place to live and play, Cheers and Merry Christmas to you downunder.
  16. The Following User Says Thank You to Captainleeward For This Useful Post:
  17. #9
    Great remedy Captainleeward. Beats my method; sprouting a third arm and hand to clamp with barstock bridging the ribs, including DP's without slots at all. Uncomfortable, troublesome too - finding tailors accustomed to fitting oddly placed appendages.
    Thanks for your contributions, Merry Christmas, Happy New Year to you with Fair Winds and Following Seas.
  18. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  19. #10
    Thelt's Avatar
    Very good idea. I like it a lot and I'm going to do that on my DP. Thank you, sir!!!
    When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
  20. The Following User Says Thank You to Thelt For This Useful Post:
