Results 1 to 4 of 4
Thread: Drilling a Hole In the Center of a Rod without a Lathe
Hybrid View
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Drilling a hole in the end of a rod is easy... if you own a lathe. Here is a trick for doing the task using a drill press. Don't own a drill press? All is not lost if you own a bench block or a block of metal drilled to the rod's diameter on a borrowed drill press.
    https://rick.sparber.org/CenterDrillingNoLathe.pdf
    Thanks,
    Rick
    Rick
  2. The Following 18 Users Say Thank You to rgsparber For This Useful Post:
    amarlow (Aug 27, 2020), Andyt (Aug 25, 2020), Baddog (Aug 31, 2020), baja (Aug 25, 2020), benkeller3 (Aug 27, 2020), bruce.desertrat (Aug 24, 2020), CharlesWaugh (Aug 24, 2020), Dollar Bill (Feb 18, 2023), emu roo (Feb 13, 2023), EnginePaul (Sep 2, 2020), Jon (Aug 27, 2020), lassab999 (Apr 15, 2024), PDXsparky (Aug 30, 2020), Sleykin (Feb 18, 2023), tenncf (Sep 5, 2020), Tooler2 (Aug 30, 2020), wolfpaak (Feb 14, 2023), xl54ss (Feb 13, 2023)
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Way cool! Excellent way to center drill.
    It's quick and accurate 'enough' for everything I do.
    Thanks!
    Charles Waugh
    www.charleswaugh.com
  4. The Following User Says Thank You to CharlesWaugh For This Useful Post:
    rgsparber (Aug 30, 2020)
    May 2016
    Don42's Tools
    Another use: make such a jig same major diameter as the stud you just broke off. Drill the smaller hole, flip the jig and set it on the broken stud. Now you can use the smaller drill to get a starting hole exactly centered on the broken stud so you can drill it out without barfing up the threads in whatever the stud is in.
  6. The Following 4 Users Say Thank You to Don42 For This Useful Post:
    Dollar Bill (Feb 18, 2023), EnginePaul (Sep 2, 2020), rgsparber (Aug 31, 2020), wolfpaak (Feb 14, 2023)
