Results 1 to 10 of 18
Thread: Easy furnace burner for propane forging
Hybrid View
    Supporting Member MountainMan's Avatar
    Jul 2018
    Conway,SC
    MountainMan's Tools
    I have been using a coal forge for along time and decided this week I want to try out using propane. So I sat down and sketched out what I thought would be the easiest burner assembly that wouldn't cost a lot to make and wanted to share it with you all. I came up with this,,, It is constructed of a black iron pipe and went together in about 4 hours once I gathered all my material. First I took a 12" piece of 1" black iron and drilled a 11/16 hole in it for the 3/8 pipe to slide threw. Then I drilled 3-3/8 hole 5/8 of an inch apart. The 4" piece of 3/8 pipe gets a hole dead center with a #57 drill bit. One side of the 4" nipple gets a cap and the other side gets a 90*. The 8" nipple comes out of the 90* and gets a coupling threaded on it then the 3/8 mipx3/8 flare threads into that. This is where your regulator hose threads onto from your propane tank. Last I locked the burner in a vice and made sure the 1" pipe and 3/8" pipe where parallel and welded around the hole where the pipes run threw each other. I am currently waiting on my new furnace to cure and when it does I will be sure to post a video of this burner in action. I will also post a material list below in case anybody is interested in building one of these for themselves. All in all with the regulator I have about $65 in this including the regulator which I will post a link of the exact one I bought from ACE Hardware in the parts list.
    FURNCE BURNER PARTS LIST
    1"x12" Black Iron nipple
    1"x1 1x4" Black Iron reducer coupling
    3/8"mipx3/8"male flare coupling
    3/8" black iron coupling
    3/8"x8" black iron nipple
    3/8" black iron 90*
    3/8"x4" black iron nipple
    3/8" black iron cap
    Yellow (for gas) thread tape
    11/16" drill bit (to drill threw 1" pipe for 3/8" pipe to go threw)
    3/8" drill bit (for breather holes)
    #57 drill bit (gas hole in 3/8" pipe)
    Link to regulator,,,,
    https://www.acehardware.com/departme...content=Grills
    3/8"
    Dave
    "I have not failed...I've just found 10,000 ways that wont work"
    Thomas Edison
  2. The Following 22 Users Say Thank You to MountainMan For This Useful Post:
    Andyt (Sep 11, 2020), baja (Dec 12, 2018), Captn Roy (Aug 14, 2018), drivermark (Aug 13, 2018), high-side (Aug 14, 2018), j.bickley (Aug 13, 2018), JD62 (Aug 13, 2018), Jon (Aug 11, 2018), madmick77 (Sep 11, 2020), neilbourjaily (Dec 11, 2018), oldcaptainrusty (Aug 13, 2018), PJs (Aug 15, 2018), Priemsy (Aug 13, 2018), Ralphxyz (Mar 9, 2024), rlm98253 (Aug 13, 2018), rossbotics (Aug 13, 2018), Seedtick (Aug 13, 2018), that_other_guy (Aug 17, 2018), thehomeengineer (Dec 12, 2018), Toolmaker51 (Aug 13, 2018), Tule (Aug 14, 2018), winmac (Aug 25, 2022)
    Jul 2016
    I will be interested to see how this goes as I will need to make one soon. I have seen other styles of burners before but not like this. Looks quite easy to construct.
  4. The Following User Says Thank You to auswelder For This Useful Post:
    MountainMan (Aug 14, 2018)
    Supporting Member Drew1966's Avatar
    Oct 2016
    What size is a #57 drill bit please?
    Sep 2012
    Hinchinbrook QLD
    Quote Originally Posted by Drew1966 View Post
    Here you go Drew.
    http://www.smithbearing.com/images/p...ionalChart.pdf
    And I found that on google faster than it would have taken you to type your question
    No charge, Phil
  7. The Following 3 Users Say Thank You to 12bolts For This Useful Post:
    MountainMan (Aug 14, 2018), olderdan (Dec 12, 2018), PJs (Aug 15, 2018)
    May 2018
    Forge burner
    I believe it is the same size as a #4 screw. I just drilled a hole and tapped it using the #57 bit. If I can find another screw, I’ll measure and post the size.
    Download plans for forging and casting tools.
    Oct 2016
    Thanks Phil.
  10. #7
    Apr 2017
    Good morning Very interesting ,I would like to see the end result. I do have a oil burner, got any ideals? Good Luck AL
  11. The Following User Says Thank You to hilerioal@outlook.com For This Useful Post:
  12. #8
    Dec 2013
    Florida
    rossbotics's Tools
    Good job, I need to do something like that myself
    Doug
    Comments are always welcome
    Doug
  13. The Following User Says Thank You to rossbotics For This Useful Post:
  14. #9
    Supporting Member high-side's Avatar
    Jun 2018
    I would like to see a short video of it in action when you get the time.
    Pat
  15. The Following User Says Thank You to high-side For This Useful Post:
    PJs (Aug 15, 2018)
  16. #10
    Jul 2018
    Conway,SC
    MountainMan's Tools
    Quote Originally Posted by high-side View Post
    Pat
    I should have a video uploaded to youtube by the weekend Pat. I will post a link here once I get it done.
    Dave
    Thomas Edison
  17. The Following 2 Users Say Thank You to MountainMan For This Useful Post:
    neilbourjaily (Dec 11, 2018), PJs (Aug 15, 2018)
