allenz (Oct 28, 2023), baja (Dec 26, 2018), bimmer1980 (Aug 30, 2018), Catfish (Jul 31, 2024), durrelltn (Jul 31, 2024), emu roo (Jul 31, 2024), jamesjinks (Oct 8, 2018), Jon (Aug 28, 2018), Miloslav (Dec 25, 2018), mr mikey (Nov 1, 2022), Paul Jones (Aug 29, 2018), PJs (Aug 31, 2018), rgsparber (Sep 2, 2018), rlm98253 (Feb 17, 2022), rossbotics (Aug 29, 2018), Seedtick (Aug 29, 2018), Sleykin (Feb 17, 2022), Toolmaker51 (Sep 3, 2018), TSiArt (Aug 30, 2018), whitebear (Dec 4, 2023)
emu roo (Sep 5, 2025)
Thanks almarghi! We've added your Drill Press Handle to our Drilling and Drill Presses category,
as well as to your builder page: almarghi's Homemade Tools. Your receipt:
I admire this project. I power-tap frequently on various machines, our drill press being the least accommodating. This would solve it.
I'm interested what means attain a convenient "o'clock" position. Table height is a good start, with tapping a relatively shallow operation. Could a clamp substitute a knob, readily moved to any of the three arms, or 3 half-knobs?
Digging around, turned up what seem a finger operated cutting fluid dispenser. O-Rings deteriorated, but the remainder seem fine, but haven't determined all parts are present. Too busy working for time to dive into it. A shop-made thing, it seems to use a reservoir, small capillary tube, and a spring loaded 'piston', in a compact aluminum body. Gravity fed, the O-ringed piston rod interrupts flow from vented tank to lower tube. Lower tube, I envision inside a sleeve to aim fluid where intended. A light compression spring is missing (?). Cool part, it could be set where other hand [left for most of us] could operate, while right is engaged feeding drill or tap.
Sprays and brushes are fine but use w-a-y more liquid than needed and triple clean up effort afterward.
Back when I had a drill press that had the adjustable rotational speeds to do power taping I had 3 different sizes of the tap o matic style self reversing devices. No need to reverse the drill press.
the only drill press I ever had that could be stopped instantly is my 7.5 HP Cleeremen but it is a jig drill not a drill press per-say.
I have been thinking about converting 1 of my belt driven drill presses to a change gear head using a variant of
LMMasterMariner's http://www.homemadetools.net/forum/2...ans-more-69285
