Thread: Electric shock while pressure washing moped - GIF
    Electric shock while pressure washing moped. There's a lot to see here. Note how the shock locks up his hand so that he can't un-grip the pressure washing gun. And how the shock seems to change once his flip-flops fall off. What is the initial error or errors here? No GFCI? Anyway, it's impressive how this guy manages to flip off the power.
    Ungrounded 480 volt electrical connection - GIF
    How electricity is delivered - photo
    Electrical pole burns through and explodes - GIF
    Melting a wrench with electricity - GIF
    carloski (May 26, 2022), DIYSwede (Jul 8, 2019), dubbby (Oct 4, 2020), EnginePaul (Dec 4, 2020)
    Stockholm, Sweden...
    DIYSwede's Tools
    Poor guy - but he seemed to survive this blind-date with Darwin.
    Kids - don't try this at home:
    -Use an ungrounded extension cord without a GFCI hooked up,
    so that when the pressure washer get "live", either from a fault or a mere water-conducted leakage current,
    the mains voltage gets carried to the handle, through your cramping hand, your body and wet flip-flops to the ground.
    Had the safety ground been used, the live voltage chassis would've blown the fuse,
    and for redundacy: a GFCI checks in-and out-going current from live to neutral:
    more than a ca 20 mA difference (i e leakage to ground thru our intrepid moped.cleaner) and it trips.
    Supporting Member cognitdiss's Avatar
    Aug 2021
    SF Bay Area, CA
    Chances are there was no neutral- this was likely 220vac...
