Results 1 to 6 of 6
Thread: Engine cylinder honing tool - GIF
    mwmkravchenko (Aug 11, 2023), nova_robotics (Aug 7, 2023), piper184 (Aug 8, 2023)
    Lake Tahoe
    IntheGroove's Tools
    I think he's going up and down too fast...
    Quote Originally Posted by IntheGroove View Post
    Not for the speed of the flexhone. The angle on the cross hatch is not enough, so he needs to go up and down faster or slow the drill. Slowing the drill would be the best option.
  5. The Following User Says Thank You to tonyfoale For This Useful Post:
    hemmjo's Tools
    Technically that is a glaze buster not a hone. The difference is a STONE hone will be used after boring to finish a cylinder, make it round and can remove imperfections. Used properly GOOD stone hone can be used to enlarge a board if necessary. The glaze buster will actually exaggerate any imperfection in the bore. Similar to the way that semi trucks will "transfer" an imperfection in a highway surface down the road. As each ball bounces out of an imperfection in the cylinder, its skips the next section of cylinder and slam down making another imperfection.
    Ball hones do have their place. Like any tool they have to be used correctly. You will often see Top Fuel or Funny Car crews use a ball hone between rounds to help their engine maintain good lubrication of the 1000 foot run.
  7. The Following User Says Thank You to hemmjo For This Useful Post:
    schuylergrace (Aug 7, 2023)
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    It won't last long, still has a ridge, I would install new sleeves, the way it sits you would be lucky to get 50,000 miles.
    Supporting Member bob_3000's Avatar
    Aug 2020
    Quote Originally Posted by mr mikey View Post
    Maaaany more reliable miles than that as long as they keep pouring oil into it.
    It's unlikely those folks have sleeves.
  10. The Following 2 Users Say Thank You to bob_3000 For This Useful Post:
    Frank S (Aug 7, 2023), mr mikey (Aug 7, 2023)
