Results 1 to 10 of 26
Thread: EV Anvil (exhaust valve)
  1. #4
    Ed. I'll offer an explanation which may be of use to others as well. Any hard object becomes an anvil when another object is placed or laid on it and struck with a 3rd object the 3rd object becomes a hammer regardless of shape or weight this is also true of an anvil. A person could place a nut on any surface then strike it with their fist the surface is the anvil and the fist is the hammer
    I often use the counter weight on my forklift as an anvil when I need a very large hard surface to assist in shaping sheet metal also I often use 2 hammers by holding 1 as a back up while striking with the other the back up hammer is at that instance an anvil.
    If the object being used as an anvil also has a particular shape that something is formed into over or around then it could be called a die as well
    LMMasterMariner's use of a large diameter exhaust valve is just one more example of the many things which can be utilized as beneficial simple tools readily at hand
  2. The Following 7 Users Say Thank You to Frank S For This Useful Post:
    baja (May 1, 2020), Beserkleyboy (Jun 20, 2018), Big Sexy (Apr 30, 2020), emu roo (Dec 16, 2025), gunsgt1863 (Jun 20, 2018), LMMasterMariner (Jun 21, 2017), Scotsman Hosie (Mar 6, 2018)
