The picture with the large long bundle on the forks raised high in the air is inside of a cold room walls were 12 meters tall the steel clad sandwifh panels in the bundle were 12 meters long 1meter wide and 200 mm thick to go on another wall the room was 30 meters long by 30 meters wide and just one of more than 20 such rooms inside of the building structure, to be brought down to -40° and held at that temperature for 3 months during the mid summer's Heat in Kuwait before it would receive certification from the Dep. of the US Navy who would be leasing the building on a 30 year lease.
This is the foam spray rig I assembled for sealing the building structure itself and spraying 200 mm of foam over the top of the ceilings of all of the rooms.
I made a small trailer then mounted a 7.5 Hp air compressor on it with the Glass-craft spray rig along with 90 meters of hose not all of it is connected in the picture
Name:	Iso foam rig 1.jpg
After the cold storage project was completed I started up a roof sealing division within the company to spray the foam on existing steel roofs then painted with a white ceramic UV stable thermal coat paint
Name:	Iso foam rig 2.png
