I have a contrator saw and like you it is not always accurate. It's strong enough, but it does not always lock equally in the position every time.
You probably have a way to adjust the fence. Try to get it as accurate as possible and learn to live with it. I doubt you will be able to create a fence that will be more accurate. Unless it is a flexing issue like others suggested.
If you need very accurate cuts on small pieces, I suggest you build a crosscut sled.
