Results 1 to 4 of 4
Thread: A few of my homemade tools.
    webby's rigginations's Tools
    I joined back in November of 2016, but can't seem to find my original post. I was asked to show some pictures of my lathe and drum sander, so here goes.
    The sander is run by a furnace motor. The drum moves up and down, mounted on a hinged box. There's a fan blowing on the motor, hooked up to a timer. The drum is a shaft from an old grinder, wooden inserts, 3" PVC pipe, gorilla glue, and 36 grit sandpaper. Frame is an old sewing machine.
    The lathe is powered by a washing machine motor. The shaft is from an old homemade grinder found in a pile of rubble. I use a drill chuck on both head and tail stock. The bed is 2x4x1/16 tube steel. The top hinges so I can work with the lathe while standing or sitting. After I took these pictures, I added a light and a port to hook up my homemade dust collector. No pictures of that yet. Essentially, I used two 55 gallon drums, a leaf blower and a bucket.
ID:	17962Click image for larger version.
ID:	17964Click image for larger version.
ID:	17965Click image for larger version.
ID:	17966Click image for larger version.
ID:	17967Click image for larger version.
ID:	17968Click image for larger version.
ID:	17969Click image for larger version.
ID:	17970Click image for larger version.
  2. The Following 3 Users Say Thank You to webby's rigginations For This Useful Post:
    Jon (May 19, 2017), olderdan (May 22, 2017), rossbotics (May 19, 2017)
