Thread: Fitting coolant tank to 4x6 bandsaw
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    After finishing the rewire the next job was to mount the coolant tank to the custom base. The coolant tank is a commercially purchased system I purchased 30 years ago and was originally on my pillar drill.
    To stop the tank from moving, it was clamped to the base with 4 pieces of aluminium angle 32x32x5mm.
    The angle was cut and the edges machined square. A hole was then drilled into each bracket 6mm for 6mm bolt. The brackets were then slightly bent to create a clamping action when fully bolted back to base.
    To ensure that all the retaining bolts were drilled in the correct position to create the clamping force a piece of the angle was drilled 2mm higher to allow for the thickness of the tank material at a diameter of 3mm. Once drilled 3mm the diameter was then opened up to suit M6 rivet nuts.
    A trial fit and the tank was securely fitted to the base. Brackets were then removed and painted.
    Fitting coolant tank to 4x6 bandsaw-854d7123-e868-4a6b-96a7-8eadeba57ba9.jpeg Tank secured in place.
    Fitting coolant tank to 4x6 bandsaw-ded143e4-4ed8-4a9a-a9e4-50065520b7c1.jpeg Drill template and brackets shot blasted ready for paint.
    Fitting coolant tank to 4x6 bandsaw-a18e0c14-7202-48c3-9b3e-f82c9ed50053.jpeg Drill template in position.
    Fitting coolant tank to 4x6 bandsaw-2ae5a946-f9e7-4b9e-b280-af0133824c2a.jpeg Fitting coolant tank to 4x6 bandsaw-93ed4369-0e9d-4d69-a644-3558fbf04c95.jpeg Fitting coolant tank to 4x6 bandsaw-9781da11-fb3f-4094-a8db-fed24b31931e.jpeg Fitting coolant tank to 4x6 bandsaw-e0a2bf22-b96e-475a-a38c-460cd9fc6330.jpeg Rivet nut in place.
    Fitting coolant tank to 4x6 bandsaw-43b5894c-3ee0-4d77-b693-0f7fa0608e74.jpeg Square showing angle to create clamping force.
    Fitting coolant tank to 4x6 bandsaw-a0a957cd-affd-4123-b238-508a7cb7b691.jpeg One completed bracket in place.
    Thank you for viewing
    The Home Engineer
  2. The Following User Says Thank You to thehomeengineer For This Useful Post:
    Philip Davies (Jan 4, 2022)
    Thanks thehomeengineer! We've added your Bandsaw Coolant Tank Mounting to our Bandsaws category,
