Results 1 to 10 of 10
Thread: Fixing Manual Mill Spindle - No Contact Between The Taper of Tool and Spindle
Hybrid View
    Supporting Member GBWM's Avatar
    Nov 2021
    GBWM's Tools
    I did something similar to covert an R8 mill spindle to an ISO 30 taper. I rotated the head to half the included angle and bored the spindle using the vertical table/knee feed. It would not work using the quill feed, that would just bore a parallel hole regardless of the angle.
    It is important that the tool edge is set on the centreline, the equivalent of setting tool height on a lathe.
    This method ensures good concentricity, better than removing the spindle and cutting the taper in a lathe where there will always be some runout.
    The same technique can also be used to repair a damaged R8 taper.
    That had to be an interesting operation. Do you have any video of the process?
  2. #2
    Quote Originally Posted by GBWM View Post
    No video nor photos and I do not even have that mill now.
  3. #3
    Nov 2021
    GBWM's Tools
    That's unlucky. But thanks for sharing the idea!
