Thread: fixture for drilling pipe
    When clamping pipes in a drill press, I find the best way is to place them in a "V" fixture Once centered the holes are 100% repeatable
    I needed to drill a series of holes in several pipes reasonably on center and close to the same distance apart.
    This is what I made to accomplish it.
    just a piece of angle iron with a couple pieces of flat bar welded to the back side.
    after clamping it to the drill table I drilled a hole through it the size of the holes I will be drilling in the pipes then moved the fixture the distance I wanted between holes and re clamped it down.
    I positioned the pipe to drill the first hole and clamped it down the fixture allows me to drill either diameter pipe I need without needing to reposition it
    After drilling the larger diameter pipes I began drilling the smaller ones. Once the first hole was drilled, I used an Allen wrench to serve as a locater pin since it fit the hole nicely without much wiggle. This allowed me to drill multiple holes in reasonable alignment both of distance and true to centerline
  2. The Following 6 Users Say Thank You to Frank S For This Useful Post:
    baja (Apr 25, 2023), Jon (Apr 28, 2023), Markdg (Oct 26, 2025), metric_taper (Apr 24, 2023), piper184 (Apr 24, 2023), trevor_60_r (Apr 30, 2023)
