Fluid reversibility demonstration.
Fluid escaping from tree with heart rot - GIF
Ferrofluid GIF
Non-Newtonian fluid-filled speed bump - GIF
Liquid scintillation counter - photos
Machinist blue layout fluid - video
Ferrofluid GIF
carloski (Aug 26, 2022), nova_robotics (Aug 25, 2022), Ralphxyz (Aug 27, 2022), Rangi (Aug 29, 2022)
T differing fluids each having approximately the same specific gravity and or density none of which are able to emulsify with the other OK that part can be real, but I take issue with the red and green fluids being returned into their original blobs right down to the tail left by the syringe
mwmkravchenko (Aug 26, 2022)
I know, I even did like you did but instead of watching the blobs I watched the hands when the hand is returned to the table where the translucent white object is the position of the arm does not match the placement of it at the beginning. I still have a doubt of the validity because seeing is not always believing unless I can witness it live in real time while it is happening, even then I don't always trust my eyes. Magicians make their living on visual deceptions
To the sceptics. I would suggest that you might consider what would happen if these were liquids with high viscosity. It is a genuine demonstration.
mccwho (Sep 1, 2022), Toolmaker51 (Sep 1, 2022)
I thought we decided from our investigations that the demonstration was real.
I believe all of our skepticism is healthy. Many of us have a "trust but verify" attitude. We must all be very aware how very easy it is to manipulate sound, photos and video now. Hearing and Seeing is not always believing today.
In regard to considering, "what would happen if these were liquids with high viscosity", it appears to me that they do have a high viscosity.
I'm unable to accept this reality at this time. Please reset the universe and check back again later.
Is the secret sauce here that the density of the liquids are the same but they can't mix?
(She says, knowing that the next couple of hours are going to be on YouTube taking this apart piece by piece.)
While the liquids aren't revealed, there is a difference between mixing, soluble-insoluble, solutions and emulsions.
First one I remember, the original water soluble cutting oils. Another bit of amazement is water and alcohol; two equal quantities result in less than logical volume. They not only mix, but integrate.
Think we'd agree both knowledge and skepticism are healthy viewpoints.
