Results 1 to 4 of 4
Thread: Flycutter resurfacing a motorcycle engine part - GIF
Hybrid View
    mwmkravchenko (Aug 28, 2021)
    Fly cutting is accurate description, a different tool would be face milling. Positive a hold down bolt in the post stacked on 1-2-3 blocks, NO WAY end clamp would be stable. They've run RPM lower with rather aggressive feed rate from normal fly cutting tuning out chatter. When you hear squeaks or dragging, that signifies a cut isn't happening.
    Doing good job with just one bit. My attempts would pair a leading chamfered bit with a slightly lowered sharp corner.
  4. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    Altair (Aug 24, 2021), mwmkravchenko (Aug 28, 2021)
    Jun 2018
    Louisiana
    I cant stop the video to get a good look but it looks like a type of boring head with the boring bar mounted vertically downward and used as a fly-cutter
  6. The Following User Says Thank You to TrickieDickie For This Useful Post:
    It is actually a boring and facing head. The demonstration takes 'facing' a little too literally.
    The designed use is radial facing, O-ring & snap ring grooves; via built in feed mechanism.
  8. The Following User Says Thank You to Toolmaker51 For This Useful Post:
