Thread: Forming Brass over MDF
Hybrid View
    Apr 2017
    UK
    editor@glue-it.com's Tools
    I needed to make two brass brackets and tried forming them over MDF:
    One of the key steps was coating the MDF in superglue
    I annealed the brass a couple of times during the forming
    The final finished pair of formed supports.
    Actually, not quite finished as I need to clean them up and add spacer bars.
  2. The Following 13 Users Say Thank You to editor@glue-it.com For This Useful Post:
    Andyt (May 3, 2022), baja (May 4, 2022), CharlesWaugh (May 3, 2022), ChasT (May 2, 2022), Christophe Mineau (May 3, 2022), Floradawg (May 2, 2022), Inner (May 2, 2022), KustomsbyKent (May 3, 2022), mwmkravchenko (May 4, 2022), nova_robotics (May 2, 2022), olderdan (May 3, 2022), rlm98253 (May 2, 2022), sossol (May 2, 2022)
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Your work is very nicely done!
    MDF+Superglue is a wonderful form material.
    I've used it for heat-bending plastic, plasma-torch forms (to run the torch around to make and exact shape), bending aluminum, etc.
    I find that the water-thin CA is the best - it wicks in deeeeeeep.
    Also, if I screw up in making my form - a bit of MDF sanding dust and CA fixxes my boo-boos.
    Charles Waugh
    www.charleswaugh.com
  4. The Following User Says Thank You to CharlesWaugh For This Useful Post:
    editor@glue-it.com (May 8, 2022)
