Step by step how I build an aluminum pulley
Greetings from Brazil
Celso Ari
Celso Ari
baja (Feb 4, 2020), BIGGUYRALPH (Feb 6, 2020), bigtrev8xl (Feb 4, 2020), Carnel (Feb 4, 2020), Crusty (Feb 1, 2020), DIYSwede (Feb 5, 2020), high-side (Feb 3, 2020), IAMSatisfied (Feb 3, 2020), Jon (Feb 6, 2020), Karl_H (Feb 4, 2020), lassab999 (Nov 3, 2022), LucasC (Feb 10, 2020), mhfcell420 (Mar 12, 2021), neilbourjaily (Feb 3, 2020), Ralphxyz (Feb 9, 2024), Resident114 (May 24, 2023), rgsparber (Feb 12, 2020), rlm98253 (May 24, 2023), Shanty (Feb 9, 2020), that_other_guy (Nov 2, 2022), thehomeengineer (Feb 4, 2020), Tule (Feb 10, 2020)
Is it stronger to case the block vs using a round extrusion that is the same diameter? I am a novice and have no idea, I can get just about any shape in any size I want at a local store, cusious why the choice is to cast the block vs cust it off the end of a round bar? Your work is beautiful, at times I really want to learn to cast as well as you! -jeff
Strength depends on the composition of the scrap used in the melt pot. If you use chunks of damaged wheels (cleaned & no powder coating) it's bound to be strong enough for most workshop castings.
Karl_H (Feb 11, 2024)
that_other_guy (Nov 3, 2022)
When I'm not buying full stick for jobs I goto The Yard Store, they price aluminum at $2.5/lb down to $1.5/lb for cut offs. I looked at an online supplier that I have used once, 3 inches of 8" 6061 round was $58. About a year ago I purchased 3" of 6" round and 5" of 4" round, bill at the yard store was $60. (I was building a base for a ball turning attachment for my 14" Rockwell lathe) I think they sell online. Is that is more expensive than casting, considering the time of the guy working? Thanks for responding, can't learn anything in a vacuum..
