Results 1 to 10 of 19
Thread: Gear Cutter
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    Thumbs up Gear Cutter
    Well I've got to start somewhere, I've been lurking around here long enough.
    Here is my approximate involute gear cutter, turned down from some un-known steel from the calculations from this siteInvolute Gears
    It was then pack hardened for 2 Hrs. at 1800* F And the teeth honed on a diamond lap.
    Set up in my homemade knee mill (Witch will be another post as soon as I get a few more pics.)
    And the final gear.
    Although I believe I forgot to add the extra for whole depth plus clearance it does run on the lathe, but a little noisier than the other change gears.
    Al
  2. The Following 17 Users Say Thank You to Al8236 For This Useful Post:
    billd (Feb 15, 2019), Captn Roy (Aug 2, 2018), Catfish (Aug 12, 2015), DIYSwede (May 22, 2019), emu roo (Jul 15, 2024), jere (Aug 12, 2015), Jon (Aug 11, 2015), kbalch (Aug 12, 2015), MR MAKER (Feb 18, 2019), mwmkravchenko (Apr 2, 2018), Okapi (Oct 31, 2017), olderdan (Oct 29, 2017), Paul Jones (Aug 11, 2015), PJs (Aug 12, 2015), sacco1 (Nov 11, 2020), Scotsman Hosie (Apr 17, 2018), Toolmaker51 (Jul 28, 2018)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Al8236! I've added your Involute Gear Cutter to our Machining category, as well as to your builder page: Al8236's Homemade Tools. Your receipt:
    olderdan's Tools
    Nice work and looking forward to some pics of your home made mill.
    Dec 2014
    Kendall Washington
    Al8236's Tools
    Your post caught me by surprise as this post is a couple years old! As to the mill, I used it for a little les than a year never really completely finished it and got offered enough for it by a shop that wanted a heavy-duty drill press with cross slide table that I was able to pay for a smoking deal on a used mill taken out of service at the Intalco Aluminum plant here.
    I think the only picture I have left of it is the one in my avitar
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
    Dec 2014
    Kendall Washington
    Al8236's Tools
    Found a couple of it just before it left for its new home, the replacement is in the background
  7. The Following 2 Users Say Thank You to Al8236 For This Useful Post:
    Jon (Oct 29, 2017), mwmkravchenko (Nov 12, 2020)
    Quote Originally Posted by Al8236 View Post
    Guilty as charged! We've been putting in a lot of work on featuring these oldie-but-goodie posts in the Must Read subforum. This includes a new Best Homemade Tools page with all of our Must Read tools, a new homepage that features new content mixed in with Must Read threads, and we now incorporate 3-5 Must Read threads into our daily newsletter.
  9. #7
    Oct 2012
    Al
    The Involute Gear Cutter is something I am going to try very soon. Thanks for posting.
    Nelson
    On a side note you use the "*" for your degree mark. There is a very special way to get the real degree mark and I'm going to let you in on it. Hold down your "ALT" and punch in 248 in the number pad to the right of the keyboard. It will show when you let go of the "ALT" key- °
  10. The Following 2 Users Say Thank You to ncollar For This Useful Post:
    Al8236 (Jul 29, 2018), PJs (Jul 28, 2018)
  11. #8
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Quote Originally Posted by ncollar View Post
    Al
    Nelson
    Nice to see this thread again...Great build!
    Alt-0176 is what I have used for years °¿°. Thanks ncollar, saves a keystroke for an old ASCII guy. Δ² ∙ Ωⁿ±Ø ≈ ∞
    Here is a table for others enjoyment and use. This website is pretty good too.
    PJ
    Mark Twain
  12. The Following User Says Thank You to PJs For This Useful Post:
  13. #9
    Oct 2012
    PJ
    Thank you so very must for the site. There is so much hidden in the keyboard most people haven't a clue about.
    Again thanks
    Nelson
  14. The Following User Says Thank You to ncollar For This Useful Post:
    PJs (Jul 28, 2018)
  15. #10
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Thank You Nelson! Hadn't explored Alt codes much but will add to the repertoire. Cut and paste works but it's nice to play with the original emoji's sometimes.
    ƒ PJ³
    Mark Twain
