Results 1 to 6 of 6
Thread: Get off a stubborn grinding wheel with no tools (to speak of).
  1. #5
    Supporting Member cognitdiss's Avatar
    Aug 2021
    SF Bay Area, CA
    I wouldn't call my setup industrial per se. I do have two basic dewalt bench grinders in my work-shop, an 8" and a 6".
    The 8" has the coarse factory stone on it, the images were of me removing the fine stone to install a wire wheel. This way I can round corners, chamfer bar stock, dress and clean threaded rod, clean rusty steel for a weld, and clearance the steel out of the way when repurposing lathe tools. This grinder has plenty of oomph for what I need, esp for the wire wheel.
    The 6" has both factory stones removed, replaced by a green stone on one side and a 150 grit diamond on the other for sharpening drills and forming & sharpening the tungsten carbide on lathe tools.
    Yes if you are sharpening carbide (my low budget way) you will need a green wheel, telescopic shims to fit the wheel to your arbor, and a cheap flat diamond dresser. Diamond wheel is nice for better surface finish w/ lathe tools.
    I don't sharpen on anything else any more. But the green wheels do not last forever, and make silica dust, so plan to deal w/ that if you go this route. Personally, this is my current ideal grinder setup, at work or at home.
    Somehow I manage to go through grinders faster than my wheel supply. If you lived in the area I would drop off a large fraction of my stash of vitrified and still have a functionally infinite amount of grinding wheel life on hand.
    Last edited by cognitdiss; Apr 17, 2024 at 09:28 AM. Reason: so many edits, so little time
  2. The Following User Says Thank You to cognitdiss For This Useful Post:
    Philip Davies (Apr 17, 2024)
