Results 1 to 10 of 12
Thread: Gold leaf gilding - need advice
  1. #7
    delta tango's Avatar
    Sep 2020
    A few more tips, from a former oil artist who successfully leafed a number of older frames. If you want a brighter gold appearance, the base project surface to be leafed should be painted a glossy, thinned, oil-based RED (Sometimes called VENICIAN or VENITIAN RED - a bright, slightly darker than Fire-Engine Red, a Vermilion Red shade would also work well). The leafing varnish goes over the red paint. The varnish is ready to leaf when it is just slightly tacky to a knuckle touch. A round paint brush is handy to burnish the leaf into detailed moldings.
    If you are Silver leafing, a bright BLUE paint base will make the silver brighter.
    A final note -- FAUX GOLD LEAF is slightly heavier-thicker, and thus far easier to apply than actual Gold Leaf.
    (A friend of mine once SNEEZED AWAY $$$ worth of 22k GOLD LEAF !) Yes, Faux Leaf will fade a bit over time, but this also gives it 'Character', and an antique-like appearance. Initially it will look just like the real McCoy. It's best to experiment with plane wood before applying either to your finished project.
    Hope this is helpful.
  2. The Following 2 Users Say Thank You to delta tango For This Useful Post:
    Inner (Jan 7, 2021), rendoman (Jan 8, 2021)
