Results 1 to 10 of 198
Thread: Good advices for a newbie (threading tools lathe)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    This thread just got my thinking cap on...no cape or mask, C-Bag but thanks for your kindness!!
    Stefano: I downloaded the HF94 spec sheet which goes back to my question above about the total depth of the horn. The HF94 is 135mm which leads me to believe that you will add another piece to the flange above. ?? I would think the length is quite important to minimize the drop in pressure/db and maintain the dispersal and f response. This makes sense as the dispersion curves for the HF94 are quite good at 2, 4 & 8k and match the driver output well. Also agree they are hard pressed to prove the 20khz top end with a 10db drop off after 10k!!
    What was interesting to me about the HF94 in the cross section view is the radial transition just above (no dimensions) exit port. I would imagine this straight section is part of the air motion chambering you speak of to increase the pressure into the actual cone. My hit is it is a tuned resonance chamber 1"ID x X"length (1/f function) to achieve greater pressure prior to the cone.
    This is where I am at a bit of a loss to calculate the dimensions based on a range of frequencies. The driver curves above have a nice little rise at about 2500hz and may be a good number to shoot for cut off?? This might give you the power/pressure point to get it out through the cone and minimize losses?? It might also be good to include the pre-chamber dimensions (diaphragm to exit point) in the calcs because it has good/solid/3D pre-chambering and will probably be modified by the additional coupling, at least to the cone transition. What is the f range you are shooting for over all?
    Seem to be drooling here...Thanks! ~¿@
    PJ
    Mark Twain
  2. The Following 2 Users Say Thank You to PJs For This Useful Post:
    C-Bag (Jan 1, 2016), rendoman (Dec 30, 2015)
