Results 1 to 4 of 4
Thread: Hack for Spreading U-bolts
    Sep 2020
    Sometimes a U-bolt is just a bit too narrow for the job. I can usually manage spreading a 1/4" diameter U-bolt by hands/fingers but wonder what knuckle joint stress I may pay for later.
    Today I realized a hack for this task when I needed to open up several 5/16" diameter U-bolts & couldn't do it by hand strength. If a vise with a step between jaws and frame is available, install nuts on the U-bolt thread ends (to protect the threads) & use the steps on the vise to push the U-bolt open a fraction by opening the vise jaws.
ID:	46010 Click image for larger version.
ID:	46008 Click image for larger version.
ID:	46009 Click image for larger version.
    Why didn't I think of this years ago??
  2. The Following 7 Users Say Thank You to remidgett For This Useful Post:
    ductape (Aug 12, 2023), Jon (Aug 12, 2023), nova_robotics (Aug 14, 2023), piper184 (Aug 14, 2023), rgsparber (Aug 13, 2023), Scotty1 (Aug 12, 2023), tuchie (Aug 14, 2023)
    Dec 2022
    Midwest US
    ductape's Tools
    Very good idea. Those type of bolts aren't always very precise and sometimes need a little adjustment.
    It may have been done but not mentioned, but it would be prudent to keep a firm grip on the bolt while spreading it this way. The rounded edges of the nuts may cause it to slip off the jaws and send the bolt flying.
    Your vice idea is a good one if the vice jaws stick up enough to grip the nuts safely. The easiest way I've found to spread U bolts up to an inch in diameter is to use a couple lengths of pipe over the bolts. Obviously the bigger the bolt the bigger and longer the pipes need to be.
  5. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    remidgett (Dec 28, 2023), Scotty1 (Aug 12, 2023)
    Supporting Member imohtep56's Avatar
    Sep 2016
    With my luck, the nuts would slip off the vice and the whole thing would smack me in the face.
    Now you know why I wear a mask...
