Results 1 to 10 of 13
Thread: Harbor Freight bead roller upgrade
  1. #5
    Quote Originally Posted by 11thhourfabrication View Post
    Harbor freight dies have a ID of 22mm. They are a soft steel and not the best units around but work in a pinch if used with respect. Hoosier profiles will make dies with any size ID you need and their products are top notch. Do you have any pictures of your bead roller to see if it can be identified.
    Thanks for that information 11thhourfabrication.
    What I have is a John Heine model 43J from ww2. My apologies for the photos - not my best and too late in the day to reshoot them.
    I will have to remove the wheels and check the dimensions but the shafts are about 25mm from memory. I works perfectly and all I have done is a strip, clean, repaint and lube.
ID:	23518Click image for larger version.
  2. The Following User Says Thank You to Mi Tasol For This Useful Post:
    emu roo (Aug 22, 2025)
