Quote Originally Posted by LMMasterMariner View Post
Hello tmate3,
The lift distance appears more than adequate, but head is the heaviest single part of this machine. It will be too much offset and I wouldn't take that risk. It is simpler to hoist it from the top. Attached couple of photos how I did it. Also some drawings which might help you with idea how to fabricate block riser. Dimensions might differ, as these are exact dimensions for Harbor Freight 6x26 knee mill. My block riser is approx. 5", actually 125 mm high.
Good luck and best regards
LMMasterMariner
Thank you for the photos & information. Did you machine the riser from a solid block, or weld flanges on to a tube? How big a lathe did you use? How did you lay out your holes and drill them if your mill was apart?
