Finally completed power feed for my mill/drill.
Cheers
LMMasterMariner
Cheers
LMMasterMariner
Bummers (Oct 13, 2023), Captainleeward (Mar 4, 2019), daddytroll (Apr 2, 2022), emu roo (Oct 28, 2024), Jon (Feb 20, 2019), mr mikey (Oct 14, 2023), olderdan (Feb 21, 2019), Ralphxyz (Mar 31, 2021), rarmintrout (Apr 1, 2021), rossbotics (Feb 21, 2019), SA MAKER (Feb 25, 2019), Seedtick (Feb 21, 2019), tonyfoale (Apr 1, 2021), Toolmaker51 (Feb 22, 2019), Tule (Feb 22, 2019)
Additional info
PWM Controller
9-50V 40A DC Motor Speed Control PWM RC Controller 12V 24V 48V 2000W MAX
can be found at
https://www.aliexpress.com/item/9-50...5bc57f6927jZ1J
Cheers
LMMasterMariner
Great Job LMMasterMariner
Lot of engineering went into that as I can very well see, should last you a good bit, thanks for sharing
Doug
Comments are always welcome
Doug
I surmise limitation of window motor is not only too little power [torque & amps] but having it's own gear reduction, RPM too slow for converting up into usable feed rate? The fan motor has all kinds of RPM so your gearbox puts out super reduction needed for milling, not just moving X axis putting here to there.
I'm not surprised, recalling that 18 speed gearbox you hung on the lathe. You have power transmission down-pat!
All along I thought your shop was onboard a vessel...until I saw hinged windows and plaster.
Too funny.
Thanks LMMasterMariner! We've added your Milling Machine Power Feed to our Milling category,
as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
