Results 1 to 10 of 18
Thread: Heavy duty transmission jack
    Many years ago when I regularly worked on heavy equipment and trucks I owned a heavy duty transmission jack the other day a friend called me to ask if I could put a clutch and rear main seal in his Mack. I told him sure why not. So he said he would be passing through in a couple of weeks after I hung up the phone I remembered that I don't have a jack any more. No problem I'll Hire my neighbor who lives about a mile away to bring his over. Big problem his is busted he needs to have it repaired. I offered to rebuild the ram for him but he had already taken it to a shop where they have ordered the parts not sure when they will be in or when he will get his jack back. So I decided to just build one.
    After looking around I pulled a couple of 4x4 1/4" sq tubes out of my usable scrap pile dug out 4 heavy duty casters 2 rigid and 2 swivel from my storage van then found an 8 ton engine hoist jack. Hauled a piece of 1/2" plate steel out of my scrap pile and 8 lengths of 1" pipe that at one time was a sprinkler system A few feet of 3/4" 1018 cold roll rod for the pivots shafts and a lenght of 1/14" chromed cylinder rod for the pivots and a few set collars that I made up previously and I was all set I had a heavy duty transmission jack the only thing left to do was cut drill and weld all of this together
    After welding the 1 " pipes together to make the link arms I needed a weld jig to make sure the ends were parallel and matching lengths
    so I already had 1 hole in the 1" thick table I used my mag drill to drill another turning the table into a welding fixture or jig
    I mig welded the ends on by welding about an inch inside of the pipes filling with weld
    After all the ends were welded on the link arms and cooled I reamed the bores using my #7 tap handle on the tang of the MT#3 shank of a 3/4"
    Pre-assembled everything before welding
    Just tacked together
    Now a fully functional transmission jack
    I used KBS rust blast to remove the surface rust and provide a pre paint primer surface
    KBS rust blast leaves a zinc coating that can either be brushed off or left in place Since I was out of etching primer I opted to just rub off and loose residue and leave the rest to serve as a primer
    Painted with KBS rust seal machinery gray
  2. The Following 24 Users Say Thank You to Frank S For This Useful Post:
    Andyt (Oct 19, 2018), baja (Oct 17, 2020), bigtrev8xl (Jun 10, 2018), Captn Roy (Jun 12, 2018), clydeman (Jan 18, 2019), emu roo (Aug 12, 2024), Jon (Jun 8, 2018), katy (Apr 14, 2023), KustomsbyKent (Jun 12, 2018), manicswede (Nov 24, 2019), Manitoba Man (Aug 12, 2024), mr mikey (Aug 12, 2024), mwmkravchenko (Apr 14, 2023), NortonDommi (Jun 10, 2018), Paul Jones (Jun 13, 2018), Philip Davies (Aug 12, 2024), PJs (Jun 10, 2018), rlm98253 (Jun 9, 2018), rossbotics (Jun 9, 2018), Scotty12 (Oct 16, 2020), Seedtick (Jun 9, 2018), sossol (Oct 16, 2020), thehomeengineer (Apr 21, 2023), Toolmaker51 (Jun 10, 2018)
