Results 1 to 10 of 36
Thread: Height gauge addition.
  1. #3
    A solid cone isn't bad as a center finder, but they don't have much 'feel' to ascertain contact with 100% of a hole in both axes. Mitutoyo's [and likely copies] is a pivoting flat arrow on a back plate, and scriber sized arm for height gauge. A fine lever-arm marks the arrow center, indicating a central location to corresponding line on back plate. Best feature is that precise vertical center isn't crucial, but works best on un-chamfered bores.
    It's not a scriber, only used to interpret relative position from a reference you establish. Simple as scribing line known height above surface plate, and positioning arrow at the line. A drill bushing atop a 1-2-3 block works for higher precision, from easily calculated center.
    It was designed and patented by a resident of Long Beach, Ca.
    https://www.google.com/search?q=mitu...aDn7A-z8lZuqM:
  2. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    olderdan (Nov 6, 2018), PJs (Nov 6, 2018)
