Results 1 to 10 of 13
Thread: Homebrew CNC Engraver
    Mar 2014
    kd8wdave's Tools
    For my 'second' post, I guess I can show my "homebrew" CNC machine. A little unsure how to show the pics
    here, but will give it a try. The machine frame is made of 1-in black-iron pipe. Saw this style from THIS website and decided to give it a try. My machine uses the 'Arduino-UNO' module. It uses the 'grbl' software ver 9. The step/direction commands from the Arduino are passed to three controller cards that I made using PIC processors. The PIC's pass the necessary driver step sequence to some "Dual-H-Bridge" drivers that in turn, drive the stepper(bipolar) motors.
    I found quite a few interesting issues that had to be dealt with, and found it quite enjoyable to work on. Shown is an very old 'dremel tool' that I had, and used for a bit for testing and checking out milling/engraving . I have received my new 3-speed spindle , but don't have it mounted yet. Other more important things to do first, but hope to have it done in the next month or two. My X axis(left& right) is about 450 mm. The Y axis (front&rear) is about 150 mm and the Z axis is about 75-80 mm.
    I use a program called 'inkscape' to do the drawing of the work-piece. There is a plug-in on the software that converts this image to the required 'g-code' file for the machine. I have found that I do have to check the file for 'grbl' compatibility and I'm still learning how this should work for best results.
    Here are a pic of my new spindle mounted on the machine. I just finished this up today after
    getting caught up from the last weeks 'ham radio' field day operation.
    Hope this all shows up okay.
    cheers
ID:	3921   Click image for larger version.
  2. The Following 13 Users Say Thank You to kd8wdave For This Useful Post:
    blkadder (Sep 15, 2015), DaveInPA (Jun 24, 2015), emu roo (Nov 28, 2022), high-side (Jul 4, 2020), Hotz (Jun 23, 2015), JiriLord (Jan 13, 2017), kbalch (Jun 22, 2015), Kevic (May 3, 2018), oldcaptainrusty (Dec 17, 2017), Paul Jones (Jun 21, 2015), PJs (Jul 23, 2015), proff11 (Jun 23, 2015), that_other_guy (Sep 3, 2018)
