Thread: HOMEMADE CHAIN BENDER
    Feb 2019
    mariost's Tools
    An easy construction we can make with an angle grinder and a drill. The 3 pins on the base after some tests are 12 X 60 mm from an old inkjet printer. The other 2 pins on the handles are 12 X 40 mm.All of them are from stainless steel. The chain is very strong from nails 6 X 132 mm . Usually in similar consructions in the net they use more thin iron about 4 mm. I had to use very strong materials. You can see all the dimentions during the description in this video. Be careful when you use electric tools.
    YOU CAN WATCH THE CONSTRUCTION AND THE USE HERE:
ID:	31949   Click image for larger version.
ID:	31950   Click image for larger version.
ID:	31951   Click image for larger version.
ID:	31952   Click image for larger version.
ID:	31954   Click image for larger version.
ID:	31955   Click image for larger version.
ID:	31956   Click image for larger version.
  2. The Following 12 Users Say Thank You to mariost For This Useful Post:
    albertq (Mar 21, 2024), baja (Nov 12, 2019), Biggus1942 (Aug 10, 2022), emu roo (Jan 31, 2025), fmerenda (Nov 12, 2019), Frank S (Nov 9, 2019), JoeVanGeaux (Aug 10, 2022), Jon (Nov 14, 2019), Little Rabbit (Nov 11, 2019), olderdan (Nov 10, 2019), SA MAKER (Nov 12, 2019), yvonf (Aug 10, 2022)
