Material is 45cm long piece of 54kg/m rr-track.
https://youtu.be/ZxR-sRFAzYw
Gorgeous work, Tuomas. The finish is fine enough to use the anvil for making jewelry; no marks left in the gold by the anvil. You're a real artist with that grinder too.
Pure talent!
What kind of cut off wheels did you use ?
thanks
animal
It was mentioned in first pinned comment.
Tools and abrasives used:
Metabo WE 2200-230 230mm angle grinder with 2mm thick 3M cubitron 2 cut off wheels. For making the cuts. Making all cuts took about 3 wheels.
Metabo WEV 11-125 Quick 125mm 1100W angle grinder with 3M cubitron fibre disc. For rough shaping and smoothening. Used two 36grit wheels.
METABO W 750-125 125mm 750W angle grinder with 3M Roloc pad.
Used: 60,80 and 120 grit Roloc cubitron papers. Two pcs each.
Brown, red and blue 3M Scotch brite finishing pads. One pcs each.
Anvil was made during two days.
Thank you . I need to get some of those
animal
Thanks Tuomas! We've added your Anvil to our Anvils category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-anvil-47"> <img src="/uploads/239560/homemade-anvil-47.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-anvil-47">Anvil</a> <span> by <a href="https://www.homemadetools.net/builder/Tuomas">Tuomas</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/anvil'>anvil</a> </div> </div> </div> </div>
Beautiful work Tuomas
beautiful finish
Doug
