Results 1 to 4 of 4
Thread: Homemade Sheet Metal Brake With Basic Tools
    Supporting Member PowerMk's Avatar
    Mar 2019
    PowerMk's Tools
    Hello Guys!
    Today I finished my homemade sheet metal brake.
    I used a steel corner 120cm with 50mm x 5mm
    M20 & M16 threaded rods with nuts
    2 adapters 1/2 ''
    Ø 26 round tube
    Ø 18 hinges
  2. The Following 10 Users Say Thank You to PowerMk For This Useful Post:
    baja (Jan 30, 2020), Gregraper33712 (Jan 30, 2020), IAMSatisfied (Jan 29, 2020), john45 (Mar 16, 2020), Jon (Jan 30, 2020), mdhatter3 (May 2, 2023), Midwestern640 (Jan 29, 2020), rossbotics (Jan 30, 2020), Scotsman Hosie (Feb 2, 2020), Slim-123 (Jan 29, 2020)
    hemmjo's Tools
    Very nice brake. From 10:08 - 10:20, you are braking a pan. I am curious how did you bend the ends, without crushing the previously bent sides?
    Thanks PowerMk! We've added your Brake to our Brakes and Presses category,
    as well as to your builder page: PowerMk's Homemade Tools. Your receipt:
    tags: brake
    Mar 2019
    PowerMk's Tools
    Thank You very much!
    Thank you !
    The bent sides is 3cm so I used a 3cm rectangle tube and 3mm steel flat bar . Stop the video at 10:17 or 18 and you will see it .
