It would have been clearer to see what you were doing, to use a rectangle piece not a previously ground piece already with the angle.
Yes, also I want to see how you get the right angle so that's perfect before grinding the hypotenuse. I know that I would use a precision grinding vise, with a precision square to set the work piece opposite side of the triangle, once I had the adjacent side ground. But seeing that shown, and a few methods of getting there is the info I would like. There's many fixturing tricks used, and that's the sort of knowledge I need. I trust my 1-2-3 block, but here it would be too thick to use to make the square angle, give the thickness of his material stock.
