In this video, I値l show you how to build a hydraulic loader from a used John Deere lawn tractor that was written off. With some modifications and simple parts, the tractor gets a second life and becomes a functional tool for heavy-duty work!
Specifications:
Engine: 17.5 HP Briggs & Stratton
Transmission: Hydrostatic K46
Reinforced Frame: 40x80x4mm square tubing,
Hydraulic cylinders: All 3 this same, piston stroke 200mm
Hydraulic pump: NSZ10 (15l/min)
Load capacity: around 200 kg
Weight: 350 kg
In this video, you値l see step by step how to transform an old tractor into a hydraulic loader for work in the garden or on the farm. Watch the construction process and see the new machine in action.
