Results 1 to 9 of 9
Thread: how I measure across a large diameter
    Aug 2012
    Australia
    desbromilow's Tools
    I can't recall where I saw this, but hopefully it helps someone in the future...
    using a framing square, and a sliding square, I can measure the diameter of things accurate enough to do belt length calculations.
    refer to the 2 example photos showing the method.....
    use a sliding square and the inside edge of the framing square as legs of a caliper - keep the sliding square in proper contact with the other leg of the framing square.how I measure across a large diameter-measure_example_l50.jpg
    read off the value from the inner scale (or use another measuring tool to get the value)
    and here the method is used for measuring the diameter of a lathe countershaft cone pulley...
    you can see the use of a spring clamp to hold everything in place to get a better measurement
    FWIW, I used a similar method to measure the headstock pulley diameters on the lathe, but instead of a framing square, I used another sliding square, set at 200mm, then simply subtracted the value on the ruler from 200mm to get the true pulley diameter. (no photos, sorry)
  2. The Following 8 Users Say Thank You to desbromilow For This Useful Post:
    baja (Mar 3, 2020), bobs409 (Mar 4, 2020), Jon (Mar 5, 2020), Moby Duck (Jun 24, 2023), Priemsy (Mar 2, 2020), Scotsman Hosie (Mar 2, 2020), shopandmath (Mar 3, 2020), sossol (Mar 2, 2020)
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    I've had 2 separate projects in just the last 10 days – each requiring a large diameter cutout, to match their equally large diameter inserts. But determining the diameter of these two different tapered objects – at the desired point of insertion – would've been a lot easier, if I'd have thought to use that neat little trick. Thanks for posting.
  4. The Following User Says Thank You to Scotsman Hosie For This Useful Post:
    Supporting Member high-side's Avatar
    Jun 2018
    I use this
    Then this
    And divide by this
    Pat
  6. The Following 4 Users Say Thank You to high-side For This Useful Post:
    Jon (Mar 3, 2020), Moby Duck (Jun 24, 2023), Scotsman Hosie (Mar 3, 2020), shopandmath (Mar 3, 2020)
    Apr 2017
    Quote Originally Posted by high-side View Post
    I use this
    Me too. Trouble is, the twine stretches – and wants to roll – on a tapered cylindrical surface. And the thought of pie gets you completely distracted – going for the ice cream.
    Howder1951's Avatar
    Jan 2016
    Egad, you have invented calipers! Great idea to combine with the adjustable try square, easy and accurate!
    Tell me, does your avatar ever request you to kiss his shiny metal #ss ? Could be he is related to Bender!
    Thanks desbromilow! We've added your Large Diameter Measuring Method to our Measuring and Marking category,
    as well as to your builder page: desbromilow's Homemade Tools. Your receipt:
  10. The Following User Says Thank You to DIYer For This Useful Post:
  11. #7
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by Howder1951 View Post
    When I built Bender, I deliberately made his posterior dull just to shut him up!!
  12. The Following User Says Thank You to desbromilow For This Useful Post:
    Howder1951 (Mar 9, 2020)
  13. #8
  14. The Following 2 Users Say Thank You to Jon For This Useful Post:
    desbromilow (Jun 7, 2020), Scotsman Hosie (Mar 9, 2020)
  15. #9
    jdurand's Tools
    Pies to demonstrate PI
  16. The Following User Says Thank You to jdurand For This Useful Post:
