Results 1 to 9 of 9
Thread: Installing A VFD/VSD On A Drill Press
  1. #5
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Quote Originally Posted by The Hobby Machinist NZ View Post
    When I was looking into VFDs I did not see any with single phase outputs. Someone else may correct me, but as far as I know these are either single or 3 phase in, and only 3 phase out.
    Yes, that's generally the case that most are 1ph or 3ph in and 3ph out. I have never done it, but I assume you could somehow run a universal motor off of a VFD. I imagine that would not be very good thing for either the motor or the VFD, nor the best way to vary the speed of single phase motor.
    Here's a good video explaining the operation of a VFD. It covers a few of the basics of electronics (what diodes do, for example), so it's a good lesson even if you aren't electrically savvy. It still goes into a good bit of detail, though, so it's useful even for guys with oscilloscopes on their benches.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  2. The Following User Says Thank You to schuylergrace For This Useful Post:
    nova_robotics (Mar 7, 2023)
