Thread: Keyway Cutter Attachment for Lathe
    Supporting Member LMMasterMariner's Avatar
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Made new tool for cutting keyways. This one is used with locked carriage and it is much easier to cut keyways this way than by moving carriage back and forth.
    Nothing wrong with that except unnecessary wear of prismatic ways and gears inside apron.
    Materials used:
    spur gear M1.5, 23 teeth (wrongly delivered)
    short piece of geared rack M1.5 - 15 x 15 mm
    2 bearings 6201 2Z
    st. steel flat bar 20 x 12 mm
    piece of scraped mild steel plate, 10 mm thickness
    M6 allen bolts
    greasing nipple
    plastic ball
    Cheers
    LMMasterMariner
  2. The Following 11 Users Say Thank You to LMMasterMariner For This Useful Post:
    byates (Apr 17, 2023), darkoford (Apr 18, 2023), emu roo (Apr 17, 2023), freddo4 (Apr 23, 2023), hobbymax (May 2, 2023), Jon (Apr 16, 2023), mwmkravchenko (Apr 17, 2023), nova_robotics (Apr 17, 2023), PaulsGarageProjects (Apr 22, 2023), Ralphxyz (May 23, 2024), Resident114 (Apr 17, 2023)
    Thanks LMMasterMariner! We've added your Keyway Cutter Attachment to our Machining category,
    as well as to your builder page: LMMasterMariner's Homemade Tools. Your receipt:
    Jan 2016
    Dubrovnik - Croatia
    Here is the drawing.
    Attached Files Attached Files
    Download plans for lathes.
  6. The Following 4 Users Say Thank You to LMMasterMariner For This Useful Post:
    astroscuba (May 23, 2024), celsoari (Apr 29, 2023), hobbymax (May 2, 2023), Jon (Apr 20, 2023)
