aphilipmarcou (Nov 15, 2017), bvd1940 (Nov 15, 2017), emu roo (Feb 24, 2026), Jon (Jan 1, 2016), kbalch (Jan 2, 2016), Kevic (Apr 16, 2018), MetalDesigner (Jan 2, 2016), Paul Jones (Jan 1, 2016), rctoywizard (Mar 12, 2016), rendoman (Jan 5, 2016), shirleyls (May 20, 2025), Workshopshed (Jan 7, 2016)
Thanks bstangaPat! We've added your Fly Cutter to our Machining category, as well as to your builder page: bstanga's Homemade Tools. Your receipt:
Brian,
That is a monster fly cutter and very well made. It produces a nice finish and for its size, it must throw chips way across the room. The 1144 SP is good choice of material for this type of tool. I also like your use of a lathe carbide insert holder and you can swap the carbide inserts with the T15 HSS equivalent sized inserts made by AR Warner (these only need sharpening on the top surface) if you need HSS.
Thanks for the video, it really helps with the build techniques, Paul
