Results 1 to 4 of 4
Thread: Large Fly Cutter Build
    Supporting Member bstanga's Avatar
    Sep 2015
    bstanga's Tools
    Here are some photos and a link to the Youtube video of the build.
    The finish was as smooth as glass, I ran it at 320, 420 and 800 rpm
    the scrap in the pic was the test piece . More info in the Video
    Brian Stanga
    Large Fly Cutter Build-2016-01-01-01.14.46.jpg Large Fly Cutter Build-2016-01-01-01.15.57.jpg
  2. The Following 12 Users Say Thank You to bstanga For This Useful Post:
    aphilipmarcou (Nov 15, 2017), bvd1940 (Nov 15, 2017), emu roo (Feb 24, 2026), Jon (Jan 1, 2016), kbalch (Jan 2, 2016), Kevic (Apr 16, 2018), MetalDesigner (Jan 2, 2016), Paul Jones (Jan 1, 2016), rctoywizard (Mar 12, 2016), rendoman (Jan 5, 2016), shirleyls (May 20, 2025), Workshopshed (Jan 7, 2016)
    Thanks bstangaPat! We've added your Fly Cutter to our Machining category, as well as to your builder page: bstanga's Homemade Tools. Your receipt:
    emu roo (Feb 24, 2026), shirleyls (May 20, 2025)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Brian,
    That is a monster fly cutter and very well made. It produces a nice finish and for its size, it must throw chips way across the room. The 1144 SP is good choice of material for this type of tool. I also like your use of a lathe carbide insert holder and you can swap the carbide inserts with the T15 HSS equivalent sized inserts made by AR Warner (these only need sharpening on the top surface) if you need HSS.
    Thanks for the video, it really helps with the build techniques, Paul
  6. The Following User Says Thank You to Paul Jones For This Useful Post:
    LyleD's Avatar
    Apr 2017
    South Africa
    Hi bstanga. The fly cutter is awesome. The use of a lathe insert holder is very clever. LyleD
    Download plans for fly cutters.
  8. The Following User Says Thank You to LyleD For This Useful Post:
