Results 1 to 8 of 8
Thread: Laser Compound-Slide Angle Setting
  1. #2
    Establishing the null y-axis position by setting the cross-slide flush with the apron seems like it might be a bit difficult to reproduce accurately. Even a small error will cause your scale on the cabinet to have a translation error.
    A more reproducible way to set the null would be to first mount the laser to the front edge of the cross-slide and adjust the cross-slide until the beam points to a reference mark on the cabinet. This would assure that the cross-slide is always in the same null location. Then proceed as you described to adjust the angle of the compound.
    BTW, your lathe is insanely clean. If my lathe looked like that, I'd be afraid to touch it lest the fingerprints show. I'm thinking you have one of those lovely French maids come in to tidy up after every shop session. (Just joking, Christophe. I'm really envious of your tidiness.)
  2. The Following User Says Thank You to mklotz For This Useful Post:
    Christophe Mineau (Mar 21, 2017)
