Results 1 to 9 of 9
Thread: Last Cutting/marking gauge
  1. #6
    Jul 2015
    Ireland
    Brendon's Tools
    Another work of art Brendan! Your fine pitch knurling and the inlay made my day. Curious about how you did the inlay. Did you pot the inlay with resin or Polyester and mother of pearl or something else? Thanks for sharing your fine work!! ~PJ
    Hi, thanks for your kind comment.
    The inlay was a bit tricky because everything was so small.
    While making the thumbscrew I drilled a depression in the brass head on the lathe.
    Into this I superglued a button I had turned earlier from a material called Juma.
    The surface of this button was dressed flat on the lathe.
    Then I took my mother of pearl diamond shape and held it down temporarily with a neatly cut
    Piece of double sided tape. Holding the diamond firmly in place with my thumb I marked around it
    With a scalpel. Then I literally cut out the recess for the shape using the scalpel and a very tiny chisel
    That I have. The Juma proved more difficult to cut and chisel than wood but I got there.
    After that it was a matter of gluing into place and then sanding down flat.
    Tricky hand work but worth effort.
    Cheers
    Brendon
  2. The Following 3 Users Say Thank You to Brendon For This Useful Post:
    kbalch (Jul 22, 2015), Paul Jones (Jul 22, 2015), PJs (Jul 21, 2015)
