Thread: Lathe Belt Sander Attachment
    hemmjo's Tools
    This is how I attached a simple belt sander to my lathe .
    My compound slide attaches with two set screws. It comes off quickly.
    Lathe Belt Sander Attachment-01-compound-slide.jpg Lathe Belt Sander Attachment-02-removes-quick.jpg
    A simple aluminum cylinder with a threaded hole in the center provides
    a secure point for attaching various accessories.
    Lathe Belt Sander Attachment-03-threaded-cylinder.jpg Lathe Belt Sander Attachment-04-threaded-adaper-.jpg
    To keep sanding girt from getting all over the machine, thick cardboard
    fits between the head and tail stock.
    Lathe Belt Sander Attachment-05-cover.jpg Lathe Belt Sander Attachment-06-cover-head.jpg
    A base made from composite deck material bolts to the cross slide. Washers take up
    space between the slide and top of the cardboard.
    In retrospect, should have made the cylinder a bit taller.
    The flex coupler (Flexable Drive Shaft)
    is then fit into the chuck, the sander down over the studs and snugged up.
    The sander has a port for attaching a vacuum which is very effective. The chips
    you see is all the escaped after removing the parting line flash from 4 sides of
    those 47 aluminum castings. (That green text on the casting points to the sanded edges)
    Lathe Belt Sander Attachment-10-not-much-mess.jpg Lathe Belt Sander Attachment-11-cleaned-casting.jpg
  2. The Following 4 Users Say Thank You to hemmjo For This Useful Post:
    butlerandrew (Oct 30, 2025), emu roo (Oct 29, 2025), Jon (Nov 1, 2025), nova_robotics (Oct 29, 2025)
    Thanks hemmjo! We've added your Belt Sander Lathe Mount to our Lathe Accessories category,
    as well as to your builder page: hemmjo's Homemade Tools. Your receipt:
