Results 1 to 4 of 4
Thread: Lathe Change Gear Cover Knobs
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I made two aluminum knobs to replace the 3/8-16 nuts and washers used to secure the lathe change cover. This cover is at the rear of the headstock to my 12” swing geared-head gap bed lathe. The knobs were made from 1.25” dia. 6061-T6 aluminum and approximately 2.1” long. The knurling is 21 pitch and the aluminum rod diameter was reduced 1.122” for a better fit for this knurling pattern. I used a semicircular shaped carbide insert for the Nikcole Mini-Systems grooving tool to machine the 0.125” wide grooves (using Copying Insert GIE-7-SC-3R). The larger diameter and longer length makes griping and turning the knobs very easy and no need for wrenches.
Name:	Knobs for Lathe Change Gear Cover.jpg
ID:	3560   Click image for larger version.
Name:	Knob for Lathe Change Gear Cover.jpg
ID:	3561   Click image for larger version.
Name:	Lathe Change Gear Cover Knobs.jpg
ID:	3562   Click image for larger version.
Name:	Nikcole  Mini-Systems Copying Insert (GIE-7-SC-3R).jpg
  2. The Following 3 Users Say Thank You to Paul Jones For This Useful Post:
    jjr2001 (Sep 1, 2016), kbalch (May 22, 2015), panosam (Jun 3, 2015)
