Thread: Lathe Change Gear Cover Knobs
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I made two aluminum knobs to replace the 3/8-16 nuts and washers used to secure the lathe change cover. This cover is at the rear of the headstock to my 12” swing geared-head gap bed lathe. The knobs were made from 1.25” dia. 6061-T6 aluminum and approximately 2.1” long. The knurling is 21 pitch and the aluminum rod diameter was reduced 1.122” for a better fit for this knurling pattern. I used a semicircular shaped carbide insert for the Nikcole Mini-Systems grooving tool to machine the 0.125” wide grooves (using Copying Insert GIE-7-SC-3R). The larger diameter and longer length makes griping and turning the knobs very easy and no need for wrenches.
    Attached Thumbnails Attached Thumbnails Lathe Change Gear Cover Knobs-knobs-lathe-change-gear-cover.jpg   Lathe Change Gear Cover Knobs-knob-lathe-change-gear-cover.jpg   Lathe Change Gear Cover Knobs-lathe-change-gear-cover-knobs.jpg   Lathe Change Gear Cover Knobs-nikcole-mini-systems-copying-insert-gie-7-sc-3r-.jpg
  2. The Following 3 Users Say Thank You to Paul Jones For This Useful Post:
    jjr2001 (Sep 1, 2016), kbalch (May 22, 2015), panosam (Jun 3, 2015)
    Those are really nice knurls, Paul Jones.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Paul! I've added your Lathe Change Gear Cover Knobs to our Lathe Accessories category, as well as to your builder page: Paul Jones' Homemade Tools. Your receipt:
    Very neat knurls. Nice work, Paul.
    Al
