Results 1 to 10 of 12
Thread: lathe chuck spider
    Supporting Member celsoari's Avatar
    Jan 2018
    Brazil
    celsoari's Tools
    lathe chuck spider
    how i made my lathe chuck spider
    greetings from Brazil
  2. The Following 15 Users Say Thank You to celsoari For This Useful Post:
    asterix (Apr 29, 2025), baja (May 2, 2020), Carnel (May 2, 2020), emu roo (May 16, 2025), Home-PC (May 1, 2020), Jon (May 1, 2020), mrsuwds (Apr 30, 2020), Okapi (May 2, 2020), old_toolmaker (May 2, 2020), rebuilder1954 (May 2, 2020), RetiredFAE (May 16, 2025), sossol (May 1, 2020), Tonyg (May 2, 2020), Tooler2 (May 8, 2020), Tule (May 2, 2020)
    Thanks celsoari! We've added your Lathe Chuck Spider to our Lathe Accessories category,
    as well as to your builder page: celsoari's Homemade Tools. Your receipt:
    Dry Gulch, Tx
    Crusty's Tools
    A method I like to use when turning a rough piece of stock is that I clamp down onto a bolt shank in the chuck with the bolt head behind the back of the jaws and the threads towards the tailstock, then I drill a hole in my material that's a close fit to the bolt shank and mount it onto the bolt and secure it with a nut, pulling the work piece tight up against the faces of the jaws. Then I can turn the piece round over the full length without having to stop and reverse the part like you would do when holding it in the jaws.
  5. The Following User Says Thank You to Crusty For This Useful Post:
    celsoari (May 1, 2020)
    Nice work. Very professional.
    Bore some holes in the plate and make sets of spacers and you can then adjust the spacing of the spider relative to the chuck face.
    For a picture, check my post here... (you'll need to scroll down a bit)
    Shop gadgets
    Depending on the type of work you do, you may want to drill a central hole in the spider. If you do, include a flange so that you can fit bushings to tailor the hole to the size needed for a particular job.
  7. The Following 3 Users Say Thank You to mklotz For This Useful Post:
    celsoari (May 1, 2020), Okapi (May 2, 2020), Tonyg (May 2, 2020)
    Apr 2020
    Parabéns Celso Ari, uma ferramenta de simples construção porém de grande utilidade!
    Congratulations Celso Ari, a tool of simple construction but very useful!
  9. The Following User Says Thank You to mrsuwds For This Useful Post:
    celsoari (Apr 30, 2020)
  10. #6
    Jan 2018
    Brazil
    celsoari's Tools
    Obrigado Rodrigo meu amigo
    Thanks Rodrigo my friens
    Celso Ari
  11. #7
    Jan 2018
    Brazil
    celsoari's Tools
    Shop gadgets
    Great idea, thanks for sharing
  12. #8
    Mar 2013
    Switzerland
    Okapi's Tools
    Thanks to post this video, it's the thing I need so often and don't take the time to make it…
  13. #9
    Jan 2018
    Brazil
    celsoari's Tools
    Quote Originally Posted by Okapi View Post
    thanks friend Okapi for the comment
    Celso Ari
  14. The Following 2 Users Say Thank You to celsoari For This Useful Post:
    Okapi (May 2, 2020), old_toolmaker (May 3, 2020)
  15. #10
    Jan 2018
    Brazil
    celsoari's Tools
    thanks for sharing
