how i made my lathe chuck spider
https://youtu.be/ggbQZc9gN7s
greetings from Brazil
Thanks celsoari! We've added your Lathe Chuck Spider to our Lathe Accessories category,
as well as to your builder page: celsoari's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-lathe-chuck-spider-2"> <img src="/uploads/232753/homemade-lathe-chuck-spider-2.png"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-lathe-chuck-spider-2">Lathe Chuck Spider</a> <span> by <a href="https://www.homemadetools.net/builder/celsoari">celsoari</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='https://www.homemadetools.net/tag/spider'>spider</a> </div> </div> </div> </div>
A method I like to use when turning a rough piece of stock is that I clamp down onto a bolt shank in the chuck with the bolt head behind the back of the jaws and the threads towards the tailstock, then I drill a hole in my material that's a close fit to the bolt shank and mount it onto the bolt and secure it with a nut, pulling the work piece tight up against the faces of the jaws. Then I can turn the piece round over the full length without having to stop and reverse the part like you would do when holding it in the jaws.
Nice work. Very professional.
Bore some holes in the plate and make sets of spacers and you can then adjust the spacing of the spider relative to the chuck face.
For a picture, check my post here... (you'll need to scroll down a bit)
https://www.homemadetools.net/forum/shop-gadgets-26297
Depending on the type of work you do, you may want to drill a central hole in the spider. If you do, include a flange so that you can fit bushings to tailor the hole to the size needed for a particular job.
Parabéns Celso Ari, uma ferramenta de simples construção porém de grande utilidade!
Congratulations Celso Ari, a tool of simple construction but very useful!
Obrigado Rodrigo meu amigo
Thanks Rodrigo my friens
Celso Ari
Thanks to post this video, it's the thing I need so often and don't take the time to make it…:(
