Results 1 to 10 of 10
Thread: Lathe stand coolant system.
    Oct 2015
    th62's Tools
    This is the coolant system I've built into my lathe stand. It consists of a 10 litre plastic jerry can, a $25 centrifugal pump off ebay, a couple of flexible nozzles and a heap of retic pipe and fittings. It's been running for eight years now with no problems. The coolant container was originally on the back of the stand, but proved a little difficult to get to to top up, so, I moved it to the side. It's a sealed looping system, so very little coolant loss and it's continually aerated, so no smells. Here's a video showing it working.
    Attached Thumbnails Attached Thumbnails Lathe stand coolant system.-15776761_226237037827369_7724532360786620298_o.jpg   Lathe stand coolant system.-15774988_226237121160694_661698380566639204_o.jpg   Lathe stand coolant system.-15731804_226237024494037_449056150927135060_o.jpg
  2. The Following 7 Users Say Thank You to th62 For This Useful Post:
    emu roo (Aug 15, 2025), H.L (Jun 29, 2021), Jon (Jul 2, 2021), Metallurg33 (Jul 5, 2021), mwmkravchenko (Jul 1, 2021), NortonDommi (Jun 30, 2021), rickivie (Jul 7, 2021)
    Thanks th62! We've added your Lathe Coolant System to our Lathe Accessories category,
    as well as to your builder page: th62's Homemade Tools. Your receipt:
    Tell us more about the rollup way cover. What material did you use?
  6. The Following User Says Thank You to tonyfoale For This Useful Post:
    Oct 2015
    th62's Tools
    Simple really, just a piece of PVC tube with bearings in each end, supported by the angle iron bracket bolted to the headstock. The cover is oil impregnated canvas which rolls up around the PVC tube. I've wound some 6mm cord around the tube at the rear, that stretches out along behind the headstock, does a 90 degree turn around an aluminium pulley, then out the back, around another pulley and down toward the floor. Tied on the end of the cord is a steel weight which slides up and down inside a PVC tube keeping the canvas taught. I'll post some pics later.
  8. The Following 2 Users Say Thank You to th62 For This Useful Post:
    emu roo (Aug 15, 2025), NortonDommi (Jun 30, 2021)
    Quote Originally Posted by th62 View Post
    ..... The cover is oil impregnated canvas which rolls up around the PVC tube.
    What purpose does the oil serve? I would have thought that it would be more likely to burn with hot swarf dropping on it. Is it because your cooling system kills hot swarf and the oil deals with the coolant?
  10. The Following User Says Thank You to tonyfoale For This Useful Post:
  11. #6
    Unkle Fuzzy's Avatar
    Near Monkeytown, USA
    Oil impregnated canvas is a tarp material. Basically a waterproof cotton fabric.
  12. #7
    Oct 2015
    th62's Tools
    Obviously I don't use coolant on absolutely everything, the oil impregnated into the roller stops swarf burning the tarp and sticking to it. Alsp keeps the canvas coolant proof.
  13. The Following User Says Thank You to th62 For This Useful Post:
  14. #8
    Oct 2015
    th62's Tools
    Click the link, the lathe bed protector is there, along with some other things I've done. https://www.homemadetools.net/builder/th62
  15. The Following User Says Thank You to th62 For This Useful Post:
  16. #9
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Nice build. Do you have any clogging problems with the drain holes? I had to make a strainer held in place with magnets that stops crap going down the plug hole.
  17. The Following User Says Thank You to NortonDommi For This Useful Post:
  18. #10
    Oct 2015
    th62's Tools
    Occasionally some swarf gets stuck in the holes as they're only 6mm, but the coolant still drains. I just poke the swarf down into the 25mm drain tube and it runs into the coolant container. The feed for the pump is well clear of the bottom. Never had any problems in eight years, save for the way oil draining into the coolant container and making junket.
  19. The Following User Says Thank You to th62 For This Useful Post:
