Results 1 to 7 of 7
Thread: Leather strap cutter
    Supporting Member the.hogman's Avatar
    Nov 2015
    the.hogman's Tools
    As a proven design found all over the web, simply a block of wood that can be clamped into a vise. The width gauge on the top can be adjusted with the two screws to set the distance between the razor bald and the gauge. The razor blade is clamped into the wood with the two screws on the side. Cannot be simpler or work better. Draw leather across the tool to cut straps the width you want. Obviously a small safety concern with the razor blade being unprotected during use.
ID:	7584Click image for larger version.
ID:	7585Click image for larger version.
    Manufacturer of Kat Eyz Banjo and Guitar Capos. Handmade and customized personally by me right here in the central part of the USA.
    www.kateyzcapos.com
  2. The Following 7 Users Say Thank You to the.hogman For This Useful Post:
    Christophe Mineau (Jan 19, 2016), Jon (Jan 19, 2016), kbalch (Jan 19, 2016), mikdk (Feb 26, 2017), Moby Duck (Sep 1, 2017), PJs (Jan 26, 2016), will52100 (Jul 26, 2019)
